No diag/ and no rev launch
Posted: Thu Mar 22, 2007 1:12 pm
i have a little problem with my s300. ive had it over a year, and WAS working great. heres the prob...i just finished some upgrades. did have a stock b17a1 running off of a wideband plx m300. what i did, added ctr pistons and buddyclub iv cams/springs. problem started when i went with the crower calibration, that was provided by spunkster.
engine runs fine.. however rev launch which is hooked up through the diag port doesnt work anymore. the check eng light first appears at start up, turns off via no codes. when i connect the diag port the rev launch doesnt work and the cel stays off as if code 0. i drove the car b4 swapping programs, ie with the p61 calibration....worked fine. now what? also, i checked, there are approx 5 volts @ diag port. thanks
92 civic cx
92 civic cx
