two problems when street tuning..
Posted: Sun Mar 18, 2007 3:11 pm
by dirtydseries
ok here it goes
started street tuning d16z6 gt30 turbo 750cc injectors 3 bar map
while i datalog i seem to keep getting a map sensor cel code ever other minute..?? i dont know why just when i datalog..
the other is im only running 9psi at the moment..
my injector duty cycle at 9psi at 5500rpm is like 98% and afr is 11.8
why are the injectors maxing out.. they are good for like 600whp..
i used the same injectors and everything on crome pro and it worked fine.. anyone got any ideas?
Posted: Sun Mar 18, 2007 10:30 pm
by dirtydseries
noone~!!?
Posted: Mon Mar 19, 2007 1:45 pm
Post your datalog and calibration
Posted: Mon Mar 19, 2007 6:02 pm
by Spanky
please post calibration. i would like to compare to my own d series settings. same as yours except i used a to4e 60 trim. and i ran 22 psi
Posted: Tue Mar 20, 2007 6:05 pm
by gSIr
did u make sure u adjusted for your injector size, also what fuel pressure are you running? Posting your calibration will help greatly
Posted: Tue Mar 20, 2007 8:50 pm
by scttydb411
what fuel pump are you using? what fpr are you using? i would suspect your issue is pressure/flow.
Posted: Mon Mar 26, 2007 12:46 pm
by dirtydseries
i fixed it it waS MY MAP sensor settings i changed from msd 3 bar to motec and boom everyhting went rich as hell.. adjusted it now at 9psi im at 52% duty
Posted: Mon Mar 26, 2007 12:47 pm
by dirtydseries
scttydb411 wrote:what fuel pump are you using? what fpr are you using? i would suspect your issue is pressure/flow.
walbro255 and stock fpr readiong 48psi fuel pressure drops to about 43 in boost imma get a aftermarketand bump it up a few psi like to 50
Posted: Tue Mar 27, 2007 6:46 am
by QUICKSILVER RACING
when in boost your fuel pressure should rise higher than 48 psi. at 45 psi static pressure and 15psi boost then the actual pressure should be around 60psi.
Check your fuel system.
