99-00 SI Owners - Need Suggestions
Posted: Tue Mar 13, 2007 6:35 pm
A customer of mine has a 99-00 SI with a OBD2 to 1 conversion using Hondata ?
The IAT sensor is located on the intake help in with a rubber bung. He wants to keep his stock manifold etc. Where do you guys suggest I do with the sensor. My thinking is that drilling hole on the upper IC pipe the sensor could easily be blown out under boost.
Don't even put it in ? and zip tie it somewhere in the engine bay ? By doing this, will Hondata be thrown off since it reads IAT for some compensation parameters ?
