switch h22a into an accord 93 f22a
i want to know if i can change a f22a engine to a h22a into my accord 93 ex... and if i can, do i have to make mods??
That is most definitely a viable swap. I did it on my 93 Accord LX. The only mods that would possibly be required is if you are going from auto to manual as I did. In that case the trans mount has to be removed and rewelded in a new position about 1/2" forward to properly mount the trans. Then you have to (obviously) add the wiring for VTEC, knock sensor and a few other things. But the stock mounts will bolt up to the H22A without a problem (other than what was previously mentioned).
