P72 ECU with s300, NOS control & Full throttle shift.
Posted: Thu Mar 08, 2007 4:41 pm
Hi, I want to Install my NOS kit, but need to learn more about how to integrate it with my ECU (JDM prelude H22a P72 ECU)
I don’t understand how the outputs work, can someone help explain the following, or point me in the direction of any old posts where this has already been covered?
A10 Extra output. I guess I select this option to control the nos solenoid (with a relay) is A10 the pin on the ECU to use?
AC Clutch - what is this output for?
Purge valve – to control a purge valve?
Secondary intake runner – to open sooner or later?
Rad fan control – to run fan more?
Alternator control - ?
I also want to set up full throttle shift, the car has cruise control but its not active, so do I need to use the standard clutch switch, or do I need to rewire it to the ECU, or do I just set it up in SManager?
Thanks, Mat
Thanks, Mat
