which ECU
CTRcoupe
which ECU
Post by CTRcoupe »
hi i have a B16B and am installing a JRSC with RC 550s soon, my question is: i want to run the S300 but my engine isnt on hondatas website, my ECU is a PCT, which ecu do i use to run this setup? thank you
Steve
Pretend that you engine is a short stroke B18C or tall deck B16A ... it depends on the vehicle. If it is an OBDI vehicle, then you can use an OBD1 ECU. If it is OBDII, then you'll need an OBDI ECU with adapter harness or OBDI ECU with OBDII connectors.
CTRcoupe
Post by CTRcoupe »
hi, thanks for the reply, i picked up a p28 with conversion harness as my car is obd2a, also grabbed up the s300, hopefully i can get this tuned properly as im worried about chargering my motor.....high compression and all....
Steve
