KNOCK KNOCK....ECUs there?
cukali
Post by cukali »
Okay, installed K-pro yesterday, loaded "Civic Si High Octane tuned" and it knocks alot all over the place. Loaded "Factory" and still knocks all over (I am 100% its knock I can hear it and when it PINGS my MIL flashes at the same time). I then add Octane Booster and filled to the top with 93 from shell.....STILL KNOCKING. Now I have tuned some of it out, but it at several several throttle positions and several rpm ranges so now I am stuck with NO table that doesnt knock....What do you suggest?
Also, I am installing a turbo (once I solve the above) and it seams colums 11, 12, and 13 elude me....how to I pull those up? Loaded some supplied turbo files but it doesnt appear.
Lastly, just to help out incase anyone has some of the same problem I had, with the EP3, your glove box will hit the USB cord when you close it and if they do not have 2 screws holding the daughter board in it will come lose on one side, the Kmanager will say connected, it will detect Kpro USB BUT it will say "Ignition OFF". You will get green lights on the board still but if you unplug the USB from the ECU the lights will go off. I had to remove the cover, add insulation to it (wasnt put there buy installer) and pull the daughter board of and back on, the green light then came on and all was "GO" from there.
rensoyka
Post by rensoyka »
1. Tuning out knock should be done with a datalog, not just the CEL flashing. Unless your knock sensor is overly sensitive or you have aftermarket cams making a lot of noise, you need to keep pulling back ignition where it's knocking until it stops. Also the condition should improve when we're off this winter gas crap, I plan on adding back some ignition in the spring and see if it takes it.
2. Option--show boost tables.
cukali
Post by cukali »
Was using datalog, added MIL and "ping" to eliminate the doubt my knock sensor was bad. Anyways, I have tuned it out pulling ignition back an enormous amount in a few spots after 10 minutes or so I may have about 30 knocks counted from hard driving. Thnx for your input, I am feeling the gas crap thing also is to blame.
For boost table there is an option of "create boost tables" in "edit" BUT when I select the options I want and then "OK" nothing happends. No boost columns still. Closed and opened...worked with them before, but do not remember having to use magic to get them to show...
anyone?
thnx
cukali
Post by cukali »
Okay, never mind, "create boost tables" which imo should show them but doesnt, found the one that says "show boost tables". Who really wants to create them without seeing them? :D
thnx
CivicVTi
Post by CivicVTi »
Make sure you subtract ignition timing for all cam timing maps. ('edit all tables' checked)
