Voltage offset
Posted: Tue Feb 20, 2007 5:50 pm
by gSIr
Hey guys, I'm tuning with an lm1 wideband. When I first set mine up there was a slight offset between the reading of the wideband and the hondata. That is easily fixed through the offset compensation. My question is, how do we know that the offset remains the same at higher voltage. I.E. higher rpms can create interference. So if the reading at idle is accurate, it might be a ways off at either end of the scale. Has anyone looked into this further, and how do u guys try to match up the readings from your wideband to the s300? I'm curious to see how everyone corrects for this problem. Thanks.
