problems with nitrous on kpro setup
Posted: Tue Feb 20, 2007 10:43 am
by syn11
Hey whats up Ive installed nitrous before on 2 different rsx's with kpro and never had a problem. Now I installed another and this one is kicking my ass cause I installed it correctly and when i hit it nothing happens. I dont know why but when I make the run no nitrous is being sprayed into the car. I even replaced all the wires for new ones and nothing happens still. I installed the relay as per hondata recommends. the activation switch has its own negative, the load goes to the ecu and positive from the switch i have goin to the battery with a fuse....can anybody help me understand this please.....thanks in advance.....
Re: problems with nitrous on kpro setup
Posted: Tue Feb 20, 2007 11:40 am
by TransformedBG
syn11 wrote:Hey whats up Ive installed nitrous before on 2 different rsx's with kpro and never had a problem. Now I installed another and this one is kicking my ass cause I installed it correctly and when i hit it nothing happens. I dont know why but when I make the run no nitrous is being sprayed into the car. I even replaced all the wires for new ones and nothing happens still. I installed the relay as per hondata recommends. the activation switch has its own negative, the load goes to the ecu and positive from the switch i have goin to the battery with a fuse....can anybody help me understand this please.....thanks in advance.....
what ecu you running?
Posted: Tue Feb 20, 2007 12:19 pm
What ecu do you have the K-Pro in?
Posted: Wed Feb 21, 2007 2:40 pm
by syn11
Spunkster wrote:What ecu do you have the K-Pro in?
my bad i have a prb ecu on the car. original ecu sent to hondata.....and i forgot to mention i had done nos on this car also before......
Posted: Wed Feb 21, 2007 4:22 pm
This sounds like a wiring issue with the relay and nitrous solenoid. I would suggest going over it again. You can test your wiring without the ecu.
