higher CR, but stock cams... do i need bigger injectors??
TurboLS
Post by TurboLS »
Basically, I am dropping some b16 pistons in my LS and am keeping stock cams for the time being. I am wondering if I need bigger injectors since I am not really changing the valve timing / airflow characteristics other than inside the combustion chamber once the valves are closed. Can I get away with my stock injectors>??
TurboLS from Team-Integra.net
(703)919-2786 (C)
They should still be sufficient as long as everything else is still stock.
