kpro problem with thermostat
vizhunz02si
Post by vizhunz02si »
i installed kpro yesterday, i follow the instruction, loaded a base map and the went for a test drive. my problem is that my thermostat on the cluster does not move when the motor get hot but yet i hear the fan come on to cool of the motor. can some one help me to figure out if i forgot some thing.
rensoyka
Post by rensoyka »
Which calibration did you use? Is this an engine swap civic? Any other pertinent mods? Did you do anything else besides install K-pro. Are there any error codes or a list of unsupported sensors in the readiness codes?
vizhunz02si
k24a4stock kal no mods no swap and kpro was the only thing i installed
What vehicle is this in?
Check that the multiplex option (under parameters/misc) is enabled.
RobGiordano
Post by RobGiordano »
Hondata wrote:Check that the multiplex option (under parameters/misc) is enabled.
I had the same problem for a while and the problem was the multiplex option was disabled.
