I've been tuning my fuel maps for the past month and I realized that when I tune the car at night it runs different than in the day, I took a closer look at my readings and found out that it's not that it's night or day, it's the power draw from my battery with my headlights.
Is there a way to make it so my headlights drawing off the battery dosn't adjust my AFR? it seems to run richer with the headlights on by about .2-.3 AFR.
wideband issue
Preccord00
I think you have found the problem. Your battery voltage should be pretty much the same with lights on or off. The voltage may drop for a second or 2, but will go right back to where it was.
Where are you getting you power and ground?
I recommend getting power from the ACC ON power source on the fuse box...this is a switched 12 volt power source. Any good solid chassis ground will work.
Preccord00
Preccord00
