Speed Sensor Bypass
steelbuster
Speed Sensor Bypass
I'm installing a B16a into my 89 Civic Si. The stock speedo is mechanical and the B16 has the VVS sender in the Trans Case. Can I remove the sensder and bypass it so the Vtec is enabled all the time? I would then hopefully be able to use my mech. cable drive. Any thoughts?
