(Question about k20 reflash with toda N2 engine kit)
Posted: Thu Feb 08, 2007 5:24 pm
by timmy8232
My check engine light is on and the error code is as follows 0341 cam positioning sensor circuit range/perfomance.The idle is a lilttle ruff and if i rev it up at a stand still when the RPMs drop it stalls.This was a swap from a base model to the type S....Hope someone can help!
Posted: Thu Feb 08, 2007 6:09 pm
It sounds like the cam gear is off by one tooth or you did not put the trigger wheel on the new cams. Double check your install.
Posted: Thu Feb 08, 2007 6:21 pm
by timmy8232
Thanks for the fast response! WOW! My mechanic says the install is rite on.Could this possibly be any thing else you can think of.Is the base model fuel pump ok for the type s engine. I think it the same but im not sure.
Posted: Fri Feb 09, 2007 2:49 pm
P0341 = the intake and exhaust sensor wheels have been swapped (they are marked I and E), or the cam chain is off by one or more teeth. Don't ignore this error and don't run the engine beyond idle until it has been fixed.
immobilizer question.
Posted: Fri Feb 09, 2007 3:43 pm
by timmy8232
My emmobilizer system indicater is on and blinking at all times when the engine is running after the swap and reflash is there a reason for this?
Also, Thanks for all of your help.Its great to know that you guys are there for us in our time of need. The car is going back to the shop on monday I hope all problems will be resolved. Thanks again! :D
Posted: Sat Feb 10, 2007 8:31 am
If you have the orignal ECU for the vehicle, enabled the immobilizer (Paramters, Misc). If you don't have the original ECU for the vehicle, then follow this guide.
http://www.hondata.com/immobilizer.html
