turbo hp?
minnis94vtec
turbo hp?
Post by minnis94vtec »
hello my name is kevin i own a 94 acura gsr 4 door. i am writing in hope someone will be able to help me get an estimate on hp. i am building a low budget turbo motor. its a b18 with crower rods, knife edged and micro polished crank, and dish pistons. a fully built b17 head but, i have non turbo cams. a skunk two intake but stock throttle body and exhaust but a magnaflow muffler. and am hoping to put about 16 pst on it. i have a block brace but not sleeved. any help would be greatly appreciated
my 4 banger will out run your 8 so ybuygm
Asc4130SD
Post by Asc4130SD »
I see 275 WHP and 225 TQ an attainable HP level. The major problem in this set up is the exhaust. Knife edgeing the crank is imo a waste of money at this HP level. There will be little HP gain if any, and engine life can be reduced if the crank is not balanced correctly. An exhaust system on a turbo car can up HP up to 15% depending on how restrictive you stock exhaust and cat are. Also, when boosting make sure you have enough fuel (high volume fuel pump and big injectors) and control timing(hondata). otherwise your built motor will be scrap metal in a matter of seconds. :shock:
