F20 vtech Help
slee15
F20 vtech Help
Post by slee15 »
Can anyone tell me whether or not an f20 will bolt up to a D16z6 non-vtech Tranny, :( automatic :( (In a 93 del sol si body)
locash
Post by locash »
I could tell you, but then I'd have to kill you. I think someone makes some sort of retarded adapter kit for doing this.
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
slee15
Simple frustration
Post by slee15 »
O.K so no one has the balls to be different and drop something other than an H22 into their cars. Wow so this going the way of alternitive music, where everyone was alternitive which in turn made everyone sound the same. GROW SOME BALLS.
Thanks to the true tuners out there that have had the drive to take a different road even though it may not always be the most published or easiest way out.
P.S. The question still remains
locash
Post by locash »
I answered your question, just in a roundabout way. No, it does not bolt directly on, but someone makes an adapter kit to do it with a 5 speed transmission, so maybe you can rig it to work with your automagic.
With that said, it has nothing to do with "balls", as much as it does stupidity in my opinion. Great, you take a shitty motor and combine it with a transmission that uses smaller (and weaker) cv joints, and what do you have? A pile of junk that requires an expensive adapter kit to make work, good job.
If you can't take criticism, give up now. I obviously have the balls to tell you that, and I'm sure I've done stranger swaps than what you are planning on attempting. If you don't want the advice of others, don't ask for it.
Locash Racing, LLC
