s200 bog on any throttle,but good idle
Posted: Sat Apr 19, 2003 8:19 pm
the setup is b16a drag 3 kit s200b w/550 saturated CPR injectors
the car starts and idles perfect. under very light throttle the car will rev to at least 4k, didnt want to go any higher. But when you give any moderate throttle the car sputters as if its on the 2step. Pulled the plugs and they were way rich. Datalogged and duty cycle was 2% o2 voltage was fluctuating like normal. stock fuel pressure. 16 degrees advance at idle.
the car isnt even drivable and i was pretty confident that the thing would at least drive to the dyno.
bad map? bad injectors?
[please help i cant wait to drive this thing)
