k20z1 swap
xtrafastcivic
k20z1 swap
Post by xtrafastcivic »
i have a k20z1 motor and a 92 eg.. will a hasport conversion harness and a 02-04 prb kpro'd ecu work? do i still need the adapter harness? will my speedometer work right ? and if not what would i have to do? TIA
You need an 04-04 engine harness, 02-04 RSX S ecu, and we recommend an 02-04 transmission.
xtrafastcivic
i read that tech already.. it helped, but i would like a more direct answer.. so using a 02-04 engine harness and ecu is the best way to swap my motor in.. if i have to spend a redicous amount of money to make my speedo work i rather not.. so does the frequency converter in the kpro work well?..
The Speed sensor converter is only for use with a 05-06 RSX.
