Another mil problem?
rtype
Post by rtype »
Am running a dc raceheader(decat) on my euro type r and can't get the mil to go out. Have tried disabling the 02 heater in the closed loop tab and disabled OBD11 this works for a minute or two then the mil comes back on. If I turn the ignition off and on it goes away and then comes back. If I turn the OBD11 on I get the usual error codes. I've tried clearing the ecu and reloading the .kal but no joy, it goes away in open loop but I dont want to leave it in open loop all the time. I have one possible theory which is I have lost the extender cable that runs to the back o2 sensor so have a loose o2 connector underneath the car and that might be affecting it?
Any ideas? :?
If you have the front o2 sensor then you should not need to run in open loop nor disable the o2 sensor heater. A good start would be to read the error code and use the manual to trouble shoot that code.
rtype
Post by rtype »
Fixed it. The problem was it wasn't showing any error codes with obd turned off but the mil light was still coming on. I found the connector that was missing and it was for the front o2 sensor not the back so plugged it in and the light went out.
Thanks for replying.
