JDM P30 Auto-Manual Conversion Help
OBD1 Kenobi
Post by OBD1 Kenobi »
In the Installation Manual it says to swap the RP18 resistor for one 1 K ohm less to change the P30 JDM EG9 ECU to manual. Someone at Hondata technical said instead to remove both RP17 and RP18 and then add a jumper to RP18. This is what I had done after clarifying it three times with him. The ECU still throws an automatic transmission solonoid code. What's up with the technical department at Hondata? Using stunt doubles there now?
OBD1 Kenobi
CRX Canada
91 CRX SiR DOHC VTEC
91 Shuttle 4WD
