JRSC + 7psi + 550's; What cal?
Posted: Sat Jan 13, 2007 2:43 pm
by knwldge54
I ordered my JRSC yesterday and will be starting off with the 7psi pulley, DCRH and Injen CAI. I've already downloaded the K-Manager software but there is nothing for that setup.
The closest ones are:
K20A2 Supercharged 5-7 Psi
K20A2 Supercharged 9 Psi
The current JRSC kit I'm getting comes with 550cc Injectors. I plan on getting it professionally dyno tuned to begin with but I don't even know where to start off at. Can anyone give me some insight into the matter.
Posted: Mon Jan 15, 2007 10:38 am
Based on the fact that you have 550s you should try the 9psi calibration and start from there.
Posted: Mon Jan 15, 2007 10:40 am
by knwldge54
^Thanks. That seems the be the only repsonse I'm getting
Do you know how long it's safe to run on that base map before getting it professionally dyno tuned. I've got a 4 1/2 hour drive to Houston.
Re: JRSC + 7psi + 550's; What cal?
Posted: Sun Jan 28, 2007 8:11 pm
by 02_4drs_jrsc
R u sure that JR sent you 550's !!! i just bought mine and they sent me 440's...check first.
Posted: Mon Jan 29, 2007 6:37 am
by knwldge54
Just took one out. Both the box and the one injectors I unwrapped are stamped SL4-550.
Posted: Mon Jan 29, 2007 7:05 am
by 02_4drs_jrsc
from RC injectors???...i'm gonna have to complain about mine :) i have the race kit and they sent me 440's....
JRSC 9 PSI
Posted: Mon Jan 29, 2007 9:02 am
by crackerjack
I have the same setup as the thread starter. DCRH, JRSC.
I am using the cal JRSCH 5-9 PSI Kal. I notice that it runs great in NA mode but when you go into boost, it is extremely rich.
I would start with adjusting fuel from column 11 to 13 first and bring AF ratio down to around 11.7 to 12.3. I noticed that depend on air temperature, the AF ratio will varies between that amount and don't forget to use Conrads air temperature chart.
Re: JRSC 9 PSI
Posted: Mon Jan 29, 2007 10:47 am
by knwldge54
crackerjack wrote:I have the same setup as the thread starter. DCRH, JRSC.
Are you using the 5-7psi kal or the 9psi kal?
I'm going down to Houston to get a St00pid tune next month.
I'm jsut concerned about going lean on the drive down.
Posted: Wed Jan 31, 2007 9:32 pm
by knwldge54
Bump for any more input...
