here's the situation, i need a go enough base map to get to the tuner. at thats about 100 somthing miles away.
00civic si
96 b18a block (built bottom end piston and rods) compression is around 8:5:1 or 9:5:1 its around there
00 si vtec head
Greddy 18g turbo bolt on kit
greddy type 24 intercooler
CTR intake cam
AEM PULLEY KIT
AEM timing gear
S300 ( no DUH! ) lol
I NEED A BASE MAP PLEASE
thanks
i hope you someone can help me
i load it up the b16 / greddy kit, sounded like shit!
I NEED HELP PLEASE !!! ls vtec / greddy turbo kit
QUICKSILVER RACING
- Contact:
For the amount you spent, I would suggest that you buy a cheap wideband O2 ssensor.
You did not mention what size injectors you are using.
I'm not sure which is cheaper. Buying the wideband O2 or using a trailer to send your car to your tuner.
You will likely damage your engine if you get a basemap from anybody else. Even experts cannot guess a very good basemap especially when you are tuning blind.
There are little things that you might forget to mention in your setup which will affect the basemap.
Things like injector size, fuel pump, fuel pressure, etc.
