Stalling all the time.
Posted: Fri Jan 05, 2007 12:57 pm
Here is the problem. same email i sent Hondata... oh boy this sux... but i've loved my Hondata #4 since day one, still do, just need to get this fixed.
Location: Calgary, Alberta Canada (Speedtech in calgary did the swap for me)
Car model/year: 2003 Acura RSX Type S
Engine type: K20a2 (i think)
ECU number: can't seem to find it.. sorry, if i find it, i'll reply right away.
Mods: Grounding wires, Injen CAI and of course Hondata #4 reflash. thats it.
Ok. to the bad problem. I keep getting a CEL on and off. my gas mileage blows goats, and the worst, is that the car keeps stalling even when the CEL goes off.
Symptoms:
Car stalls if its not idling for more than 3-5 mins on start up. I have to idle the car for 5 mins everytime i start it, otherwise it will stall when i drive. When i drive, say im goin into neutral from 3rd to stop at the light, the rpms will dip so low that my engine will stall and stall all the way to the lights or stop. It will not keep idle rpm on neutral at all.
The throttle is not responsive at first, so if your not careful with the clutch on first, it will stall again.
So basically i have to use my ebrake to slow me down as i restart my car, but here is another problem, it won't restart right away, it takes me a full 2 mins before it will restart. Its like the engine is flooded.
So basically to me it sounds like the ecu is has to relearn idle air/fuel mixture everytime it restarts. but i don't know jack about ecu's so i will leave it to the pro's.
What i have tried to diagnose:
reset ecu - result - nothing
check grounding wires - result - they are fine
inspect CAI - result - its on tight, sensor is attached and not damaged
spark plugs are fine.
Guys, i can say nothing but great things about this Hondata #4 reflash, i've had it since i got my baby at 5000kms, i love it. but now that its time to sell my car and this has been happening for a month, but i have been too busy to contact u guys. I am losing HP, vtec seems weird on me, but my rev limit(fuel cut off) is still there at 8600 rpm so i know that the H4 is still doin its job but not full capacity. My fuel mileage used to be amazing no matter my driving style and or season, but now i am loosing a full 100kms per tank of gas, and i always use 92 Octane.
I need your help please.
Symptoms:
