PLX DEVICES wideband
contectr
Post by contectr »
HI..
ihave buy the plx device SM-AFR+ DM5 COMBO for see the af/ratio in my euro civic type r with PRA ecu..
i have race header...
can i put the wideband sensor in the SO2 hole and wire the output 0-5v in the wire of so2v to see in datalog the 0-5v ??
what is the color of the wire in the so2v to put the 0-5v signal?
i have 2 white wire(think heater)
1 wire grey( ground?)
1 wire black (signal to ecu?)
Honda Ep3 stock k20a2 jrsc
You can do this only if you use the narrowband input to the ecu. I'm not familiar with the Euro wiring so I cannot tell you what pin to connect it to, but you should be able to find it by looking at a Helms manual. You will not be able to datalog the wideband readings in the software at this time.
contectr
Post by contectr »
i can't see the voltago 0-5 v in so2 v???
i wire the output 0-5v of controller plx devices to so2v..?
This will only work on a PRA, and you must input the narrowband signal into the primary o2 input.
contectr
Post by contectr »
spunkster..
i put the output narrowband to O2 primary, and the output wideband to O2 secondary?
the car work fine and i see in the datalog so2v 0-5 v?
menfou
Post by menfou »
contectr, on my Civic I use the stock narrow sensor on the first Input, and I use the 0-5volts signal from my AEM Wideband for the Second O2 input.
contectr
Post by contectr »
thanks menfou :-)
now i'm in standby..the plx devices don't arrive :(
