Solving P1166 error code
Posted: Wed Dec 27, 2006 9:55 am
I'm trying to solve a P1166 error code in my track car. I'm using a PRB ECU and I have made my own wiring harness. I have rechecked the wiring for the RSX wideband O2 sensor several times and I'm 100% sure it's right. The thing that might have caused the problem is that I wired the O2 heater relay wrong so E8 got 12V. I have rewired the relay and I'm getting 0V with the ignition on as it shall have.
1. Which IC might be dead in the ECU? I have traced E8 to IC181 so I'm thinking that's it?
2. If I disable the O2 heater in K-Pro should I then be able to read the O2 current? I still just get -37 mA, 10.7:1 A/F and 0.0 V. I have tried to datalog it and it does not change. I'm using ITB and the 48 mm ITB alpha N map in this datalog.
