Type R vtec turbo - which type ECU is suitable?
Jais
Post by Jais »
Hi, just done my Type-R 99spec Vtec turbo and used JE piston. Wondering to used Hondata ECU but which type is suitable for my engine? If i want to program the ECU personally what additional things must I have?
type-r vtec turbo
DaX
Post by DaX »
To use hondata you'll need to convert to OBD-1 and use any of the V-TEC OBD-1 computers. See http://www.hondata.com/techecuid.html
To program it yourself, you'll need:
>The Hondata system with boost, romeditor, and more than likely datalogging
>A wide band lambda meter
>A chip burner/emulator
>Preferably access to a dyno
>SKILLZ! :lol:
