Best ECU for a Hondata S300
Posted: Wed Dec 06, 2006 10:22 am
by 7rrivera7
Aside form the knock sensor circuitry on the P61, P30 and P72 that the P28 doesn't have, does it really make a difference on which ECU I should install my S300 on?
Posted: Wed Dec 06, 2006 10:48 am
by QUICKSILVER RACING
Any will do. but if your boosted and wanna use boost control then P72.
HP wise they all function the same.
Posted: Wed Dec 06, 2006 11:08 am
by 7rrivera7
QUICKSILVER RACING wrote:Any will do. but if your boosted and wanna use boost control then P72.
Please explain why the P72 for boost control
Posted: Wed Dec 06, 2006 1:03 pm
The only thins you need to look for are Knock control if you want it and vtec. Beyond that, they are pretty much all the same. The p72 has nothing to do with boost control. It is exactly the same to add boost control to any of the ecus.
Posted: Wed Dec 06, 2006 2:25 pm
by 7rrivera7
Spunkster wrote:The only thins you need to look for are Knock control if you want it and vtec. Beyond that, they are pretty much all the same. The p72 has nothing to do with boost control. It is exactly the same to add boost control to any of the ecus.
Thanks for the clarification :D
Posted: Wed Dec 06, 2006 11:58 pm
Thanks for the correction. What I meant was between JDM and USDM ECUs. JDM ECUs don't have the circuitry for boost control.
