Connection Error
Posted: Mon Nov 27, 2006 9:42 pm
by b00sted
I have been getting the connection error. i have tried it with an older laptop that has serial. it would connected for a second or two but then the connection error pops up. I also tried it on a newer laptop with the keyspan USA-19HS USB to serial adapter. It does the same thing. It connects for a second or two then the connection error shows up. I'm still able to display the ECU stuff like serial number, boost option, 3 step, and the datalog. Does anyone know what i might be doing wrong? Thanks
Posted: Tue Nov 28, 2006 10:25 am
On the ECU button make sure you have it selected as OBD1 V3.
Posted: Tue Nov 28, 2006 12:40 pm
by b00sted
cool i'll check that. is there anything else i should check??
Posted: Tue Nov 28, 2006 6:49 pm
by b00sted
i checked the ECU tab and it's on obd1 V3. i ran my laptop on a friends s200 and it works. in my car though in the error box it flashes between 8-10 errs/s. i dunno what else it could be.
Posted: Wed Nov 29, 2006 10:28 am
What is your serial number and is the light on the interface box flashing or solid?
Posted: Wed Nov 29, 2006 12:04 pm
by b00sted
The light is still solid and the serial number is s200-03772.
Posted: Wed Nov 29, 2006 1:00 pm
What exactly does it say on the ECU information wondow (CTRL-M)?
Posted: Wed Nov 29, 2006 3:00 pm
by b00sted
Posted: Wed Nov 29, 2006 5:40 pm
You say it will work on other s200s. Are they in the same ecu or the same car? HAve you tried this interface box with a different ecu?
Posted: Wed Nov 29, 2006 7:26 pm
by b00sted
we tried it on two different P72 ecu's. the one out of my car doesn't work but the other one in the other gsr works fine. Does it have to deal w/ the boost option because the one that works doesn't have boost. Does it erase anything if i switch out the interface boxes??
Posted: Thu Nov 30, 2006 10:12 am
Try switching the interface boxes, it will not erase anything.
Posted: Thu Nov 30, 2006 12:19 pm
by b00sted
is it alright if one is setup for boost while the other is for all motor??
Posted: Thu Nov 30, 2006 1:25 pm
Not if all you are doing is testing datalogging.
