Connection Error
b00sted
Connection Error
Post by b00sted »
I have been getting the connection error. i have tried it with an older laptop that has serial. it would connected for a second or two but then the connection error pops up. I also tried it on a newer laptop with the keyspan USA-19HS USB to serial adapter. It does the same thing. It connects for a second or two then the connection error shows up. I'm still able to display the ECU stuff like serial number, boost option, 3 step, and the datalog. Does anyone know what i might be doing wrong? Thanks
On the ECU button make sure you have it selected as OBD1 V3.
b00sted
Post by b00sted »
cool i'll check that. is there anything else i should check??
b00sted
Post by b00sted »
i checked the ECU tab and it's on obd1 V3. i ran my laptop on a friends s200 and it works. in my car though in the error box it flashes between 8-10 errs/s. i dunno what else it could be.
What is your serial number and is the light on the interface box flashing or solid?
b00sted
Post by b00sted »
The light is still solid and the serial number is s200-03772.
What exactly does it say on the ECU information wondow (CTRL-M)?
b00sted
Post by b00sted »
You say it will work on other s200s. Are they in the same ecu or the same car? HAve you tried this interface box with a different ecu?
b00sted
Post by b00sted »
we tried it on two different P72 ecu's. the one out of my car doesn't work but the other one in the other gsr works fine. Does it have to deal w/ the boost option because the one that works doesn't have boost. Does it erase anything if i switch out the interface boxes??
Try switching the interface boxes, it will not erase anything.
b00sted
Post by b00sted »
is it alright if one is setup for boost while the other is for all motor??
Not if all you are doing is testing datalogging.
