Software Traction Control
HRED
Post by HRED »
What do you think about this feature :
The purpose is to add a feature to enable limiter if engine acceleration is above a fixed value.
This feature will be enabled above a fixed rpm (ex : 4000rpm).
A stock engine is not able to increase its rpm more than about 200rpm in 1 second with correct traction.
If this value is above, that means the front wheels are sliping.
So 2 users values are needed :
1 : activation rpm (ex : 4000 rpm)
2 : acceleration max (ex : 200 rpm / s)
possiblity to disable this by setting accelaration max to 1000 and/or activation rpm to 12500 like over features.
I think it is not a lot of coding to make this, i already tried this systeme on racing ECU, it's great.
Nicolas DARNIS
HRED Motorsport
DipDip
Post by DipDip »
:wink:
deafy
Post by deafy »
i second that notion for traction control!!
HRED
Post by HRED »
Hondata, what do you think to add this ?
Nicolas DARNIS
HRED Motorsport
crluver123
Post by crluver123 »
i third this notion
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Motec and MSD has this kind of traction control which is activated by a switch.
You set activation RPM and rise rate in terms of rpm/sec.
It is a great idea for first gear. I dunno if it's plausible.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
Traction control needs the use of higher resolution wheel speed sensors, like the ABS sensors.
GTMcoupe
Post by GTMcoupe »
QUICKSILVER RACING wrote:Motec and MSD has this kind of traction control which is activated by a switch.
Also AEM works like this you set the desired acceleration rate of the engine , No wheel speed sensors needed, not 100% true traction control but very simple and with a bit of tunning you should be pretty close.
Cracking idea
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
boost charger
Post by boost charger »
i would like to see this option as well
Bore & Boost!!!!
"God created turbo lag to give v8's a chance" by TurboEK from SNI
http://www.cardomain.com/id/skrigz
