Idle speed motor on ITBs not opening
Posted: Fri Nov 24, 2006 8:31 am
I can't get the car to idle with the idle speed motor connected. It will idle when I disconnect it but very high. I've tested the idle motor outside of the car on a power supply and it's working (starts opening at about 5V and fully opens at 12V). But when connected on the car i'm not getting any voltage to it. I'm using the new ITB calibration and the car drives fine but no idle. I'm suspecting something's wrong in the wiring. Anyone have a good reference for the wiring diagram on a 2000 Si?
2000 Civic Si
P28 ECU w/ conversion harness
TWM ITB
TWM provided TPS
Stock MAP sensor connected to ITB common port
Bosch 4-wire O2 sensor (new)
B16A Head
B18C Block
2000 Civic Si
TWM ITB
TWM provided TPS
B16A Head
B18C Block
