Idle speed motor on ITBs not opening
irtbnightmare
Post by irtbnightmare »
I can't get the car to idle with the idle speed motor connected. It will idle when I disconnect it but very high. I've tested the idle motor outside of the car on a power supply and it's working (starts opening at about 5V and fully opens at 12V). But when connected on the car i'm not getting any voltage to it. I'm using the new ITB calibration and the car drives fine but no idle. I'm suspecting something's wrong in the wiring. Anyone have a good reference for the wiring diagram on a 2000 Si?
2000 Civic Si
P28 ECU w/ conversion harness
TWM ITB
TWM provided TPS
Stock MAP sensor connected to ITB common port
Bosch 4-wire O2 sensor (new)
B16A Head
B18C Block
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Check your tps voltage. What is it while idling?
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
97gsrhatch
Post by 97gsrhatch »
when i had my itb's on my old setup i didnt use the iac valve and i dont see how it would work cause it would only be hooked up to one cylinder!
i say just take it off and disable it!! it only sucks when its cold out cause you have to hold the gas down to warm it up depending on where you have it idling at
