k-pro?
Posted: Mon Nov 20, 2006 6:11 pm
by jbs06si
im looking to do the Greddy turbo and i see you post about k-pro...Sorry i dont know what k-pro is.....and how would it work,help???.....thanks for the help
Posted: Tue Nov 21, 2006 10:19 am
Posted: Wed Nov 22, 2006 11:05 am
by jbs06si
thank you for the help.....
Posted: Thu Nov 23, 2006 6:09 pm
by jbs06si
so if i do the k-pro is there anything i need to after that? Just plug and play or is there a program i have to deal with to make things run as they should.If so do i have to take it to a shop or can i do it?
Posted: Fri Nov 24, 2006 11:52 am
by jbs06si
sorry i also have one more question to ad on the last post: If i do the k-pro can i still piggyback the Greedy's e-management from there kit?. I already have the ecu re-flash from you guy's
Posted: Fri Nov 24, 2006 2:33 pm
The KPro is a plug in module to a stock ECU. Therefore anything to the stock ECU you can also do to a stock ECU with KPro, including piggybacks. However, there is zero point in using a piggyback once you have KPro.
Posted: Fri Nov 24, 2006 10:25 pm
by 06civicsi
jbs06si what car do you plan on using the k-pro for?if for the 06 civic si,there is no k-pro for it.
Posted: Wed Nov 29, 2006 6:54 am
by jbs06si
06civicsi,yes its an 06 si.............thanks
