input polarity?
Posted: Sun Nov 19, 2006 11:11 am
by turbotypeR
as far as the full throttle shift, launch limiter, etc, do you give it a ground or + 12v?
Posted: Sun Nov 19, 2006 11:18 am
Good question. It depends on the input:
ACS, PSP, SCS, VTP go to ground. BKSW goes to +12V.
Posted: Sun Nov 19, 2006 8:31 pm
by turbotypeR
so bksw is the only 12v? excuse my ignorance, i am new to this system. i assume when it says invert input, that means you can change it from a 12v to a ground input and vis-versa(sp)?
Posted: Mon Nov 20, 2006 10:39 am
Inverting only means that on is an open connection and when you invert it you change that to be off when the connection is open.
Posted: Mon Nov 20, 2006 10:41 am
No, invert input will swap the state of the input (on or off). The input still be either be switched to ground to +12V.
Posted: Mon Jan 01, 2007 4:15 pm
by turbotypeR
so power steering is ground?i hooked it up that way today and it doesn't work.
Posted: Mon Jan 01, 2007 6:08 pm
by turbotypeR
i hooked it to the a/c input and it worked.i still need to know about the p/s though.i am going to hook the fullthrottle shift to another output and wanted to use it. could it be that the ecu i am using had no input for it?if so,i could use another input
Posted: Tue Jan 02, 2007 11:27 am
What ecu are you using?
Posted: Tue Jan 02, 2007 6:16 pm
by turbotypeR
it's a p28.i just used a different input and it worked
