Datalogging problems
RedR
Post by RedR »
Well now that the cold weather is back here, i was doing going for some minor adjustments on my tune, and really can?t say the reason for my car not to be reading some of the columns, for example im boosting around 9 psi and its only dataloging 4 (psi), same with the idle and following columns (2,3,4) it just wont record below 2k rpms or so.
Its a stock map sensor for the record.
Any inputs on this situation?
Have you updated the software and re-uploaded the calibration? It is datalogging at normal speed? Are there any error codes? Can you provide a datalog?
RedR
Post by RedR »
I only noticed this with this latest version (last time i tuned it was with 1.5 i think).
Not geting any error codes and yes, i have uploaded the calibration again and i havent touched anything regarding the datalog configuration.
I?ll have the datalog file and map uploaded for you.
eikki
Post by eikki »
I have the same problem with the new program.
idle columns he is not showing the AF result, only on throttle.. this is strange. And the columns seems to be with some lag or something. i can't understand it..
RedR: Can you explain exactly what is not working? Can you provide datalogs, screenshots or anything else which might help explain what is not working?
eikki: Different problem by the sounds of it. Start a new thread.
RedR
Post by RedR »
Well from those 2 problems i wasnt geting values from the last boost column but i figured out the problem now.
But the other problem remains which is exactly the same as what eikki describe, i get no af results on my idleing columns.
Could you please provide a link for a previous s300 manager, lets say 1.8 just so i can check if the problem is solved.
I don?t have the log anymore but i?ll record another one.
