someone help explain Launch control
hatchblack
Post by hatchblack »
is there anything that i can set this to that i wont lose my a/c and will be a true launch. and when i tried it, it doesnt stay at the exact rpm, it fluctuates... isnt it supposed to be solid?
and i have to wire things? i know what the clutch switch is but why isnt there just a clutch switch activation?
i know what launch control does but whats the best way for me to do it?
B16T
Post by B16T »
Your AC doesnt have to be on ,The fan can be off but the Ac button has to be pushed to the On postion ,and you can set it to 5mph so once the wheels move over 5mph it turns off, It will bounce rpms depending on what you set your activation to, and limiter setting
hatchblack
it wouldnt work unless i had the fan on without rewiring anything
BB2H22
Post by BB2H22 »
Put it on always on, switch Mph to 3. Yes its supposed to fluxuate.
TurboLS
Post by TurboLS »
wire your clutch switch to any of the inputs you can spare.. for ex. I use the D6 VTP (VTEC pressure) pin as my clutch activation input for both launch control and full throttle shift... Since my car is non-VTEC, I'm not losing anything... hope this helps...
TurboLS from Team-Integra.net
(703)919-2786 (C)
civicbynature
Post by civicbynature »
Why are you rewiring anything. The clutch switch is already wired in that way you have to press the clutch to start the thing. less it's a conversion from an automatic.
hatchblack
i dont know... i read something about it being wired up to something. i used it with the a/c switch but i want to be able to use the a/c in the summer. and i was wondering why it wouldnt stay a constant rpm when i set it.
TurboLS
Post by TurboLS »
the Honda ECU does NOT have a way to monitoring the clutch switch.... you have to wire the clutch switch into one of the inputs in Hondata to be able to use it....
(703)919-2786 (C)
hatchblack
ive used it. it works. i just dont want to lose my a/c or anything
TurboLS
Post by TurboLS »
there's gotta be something u don't use lol...
(703)919-2786 (C)
hatchblack
well i mean, i can set the deactivation point at a low mph
i just gotta find out why my check engine light is on. i ran the jumper and it shows the ecu... i think. i dont remember. when i turn on the car it takes a second for the light to cut on. my bro can do a diagnostics and/or whatever hell do and find it, i just gotta make it over to his shop where hes got all the goodies
TurboLS
Post by TurboLS »
u do know you can check codes with hondata, right??
(703)919-2786 (C)
hatchblack
yeah but i dont think it sees it? i havent ran my laptop with my ecu in a while. the code showed after i switched to type r map and changed a bit up there but now even if i put it to gsr it still messes up...i think, like i said, its been a while
i think the bb2h22 or whatever dude explained it quite well about what to do to get it running right
