Honda Type-r speed signal
Posted: Wed Nov 08, 2006 10:51 am
by dex
I have a 2002 Honda Type-r rally car I have instlled LSD in the transmission, but because of this I no longer heve a speed signall, can I solve this with Hondata. can Hondata operate without speed signal?
Posted: Wed Nov 08, 2006 11:10 am
What is the chassis code, what sort of engine do you have and what is the ECU code?
Posted: Fri Nov 10, 2006 2:32 pm
by dex
Its an EP3 Type r. I will collect the rest of the data you need.
Thanks.
Posted: Mon Nov 20, 2006 1:46 am
by dex
Chasis no.: SHHEP33501U000274
Engine no.: K20A21000225
I do not know my ECU code.
Is this info enouhg for you to answer my question?
Posted: Mon Nov 20, 2006 10:45 am
Check the ECU has a 37820-PRA part number.
You can run a constant 80 kph speed signal in the KPro. The only issue is that the reverse lock out has to be disabled.
Posted: Mon Nov 20, 2006 10:51 am
As long as you do not care that you will not have a correct speedo reading on the dash, then you can use the K-Pro and set a constant speed signal within the ecu.
Posted: Tue Nov 21, 2006 3:14 am
by dex
I dont care,i dont need speed reading, its a race car. what about ABS if I take out my ABS, will it couse a problem?
Posted: Tue Nov 21, 2006 9:26 am
The ECU doesn't care about ABS.
