Water Temp Comp w/ No IAC?
ranta18
Post by ranta18 »
Setup:
13:1 H22
No IAC
100 Octane
50-60 deg F outside temp (I hate this shit!)
I just downloaded the new 1.1.9 version of SManager. Before when I would start the car it would idle really rich (between 11 and 12.5) and then slowly warm up and idle at 14.5 when it was at around 180 deg ECT. I noticed the old and new SManager software has it adding fuel when the engine is colder. Mine seems to need the opposite. Is this due to me not having an IAC? I have it in open loop all the time since I'm still working on the daily drive tune. I will always let the car warm up to at least 150 before driving. For adjustment points I have -40, 40, 70, 100, 130, 150, 165, 180, 199 degrees. I just want it to start up, idle, and warm up with the a/f around 14.5. Suggestions?
Also, on the open and closed loop high engine load part, I wouldn't see myself ever being at high load unless its 160+ deg ECT.
Mike Ranta
12:1 cold and 14.5:1 is normal, and doesn't need adjusting.
ranta18
Post by ranta18 »
So idling at 12:1 for 10 minutes until its warmed up is ok? Wouldn't it be better to idle at 14.5 all the time? Wouldn't it warm up faster too? Seems that when I'm driving around and the car is cooler it runs rich also. Other than the gas savings, fouling out the plugs and washing the rings out from being rich are a concern.
Mike Ranta
ranta18
Post by ranta18 »
Nevermind... I adjusted the values to be -10 at 70 degrees and getting smaller to be -2 at 150 degrees. Warms up at 14 to 14.5 the entire time.
Mike Ranta
