Full Throttle Shift
Posted: Tue Oct 10, 2006 12:46 am
by Khuna
How do you get Full Throttle shift to work? If I want to designate my AC button to activate FTS, how do I proceed? Do I have to run wires to the ECU?
What if I want to designate the same AC button for launch control as well? Will that button work for both functions at the same time?
Posted: Tue Oct 10, 2006 9:25 am
You normally would wire a clutch switch into the ECU AC switch input for both launch control and full throttle shift.
Posted: Tue Oct 10, 2006 9:28 am
You must wire the clutch switch to the input you wish to use. You can use the same input for both full throttle shift and launch control. Using the AC input for them will mean that you can no longer control AC with that input.
Posted: Tue Oct 10, 2006 10:10 pm
by Khuna
Where's the clutch switch? If I do what you guys say, to activate it all I have to do is push the AC button to activate it right?
Posted: Wed Oct 11, 2006 9:46 am
No
The clutch switch is on the clutch pedal assembly. You must connect the clutch switch to the ac input on the ecu. You will no longer be able to use the AC button in your car.
Posted: Wed Oct 11, 2006 12:38 pm
by Khuna
Do I do anything with the wiring on the AC button then? I'm not too worried about AC becuase I don't have AC. Is it just one wire for the clutch switch?
Posted: Wed Oct 11, 2006 12:58 pm
by locash
Riddle me this, assuming I am understanding this correctly, why in the world would you want to push in the A/C button before every shift?
I may be misunderstanding your question though, if so, ignore my idiotic question and proceed with yours.
Posted: Wed Oct 18, 2006 2:46 pm
by Khuna
I thought that you hook it up to the A/C switch so that when you want to activate the FTS feature, you press it. So, you're not driving all day with FTS on...
Posted: Thu Oct 19, 2006 9:35 pm
by EG6Turbo
Khuna wrote:I thought that you hook it up to the A/C switch so that when you want to activate the FTS feature, you press it. So, you're not driving all day with FTS on...
That's what I thought.
Posted: Fri Oct 20, 2006 8:10 pm
by locash
Why would it be a problem to leave the FTS on at all times? It won't matter unless you push in the clutch and try to rev the car to the rev limiter.
Posted: Thu Nov 09, 2006 11:14 am
by TurboLS
With FTS always on, your FTS RPM becomes your new redline
Posted: Thu Nov 09, 2006 11:16 am
by TurboLS
And to clear up the whole input thing... Basically, all the options in the drop down menu are ones that you can use that are already connected to the ECU. You simply have to cut the other end and re-wire to the clutch switch... For example, my car is non-VTEC, so I use D6 VTP as my FTS activation input and I have wired it to my clutch switch located on the pedal assembly...
