SManager V1.1.8 and High/Low Boost Option
Posted: Fri Oct 06, 2006 6:47 am
by Butch
Saw in V1.1.8 that there is selection for high/low boost. Searched Help. Can not find anything about how to set it up. Using GM Boost Solenoid, do you need external switch and how do you set the high and low boost setting?
Any instructions any where?
Posted: Fri Oct 06, 2006 8:41 am
Look in the help file under 'Boost Control Parameters'.
You need an external switch. The boost level is set in the 'boost by gear' (low and high) tables.
Posted: Fri Oct 06, 2006 8:59 am
by Butch
Went to the help file, boost parameters, nothing there about boost control (PWM) output on A11. Will the switch be low or high when grounded? Or can I just invert to change it to what I want?
Posted: Fri Oct 06, 2006 9:24 am
search "boost control parameters" in Help, Contents.
Posted: Fri Oct 06, 2006 9:31 am
by Butch
Thanks! I was using the contents to find it instead of search. Found it, explains everything.
