SManager V1.1.8 and High/Low Boost Option
Butch
Post by Butch »
Saw in V1.1.8 that there is selection for high/low boost. Searched Help. Can not find anything about how to set it up. Using GM Boost Solenoid, do you need external switch and how do you set the high and low boost setting?
Any instructions any where?
1997 ITR
Look in the help file under 'Boost Control Parameters'.
You need an external switch. The boost level is set in the 'boost by gear' (low and high) tables.
Butch
Post by Butch »
Went to the help file, boost parameters, nothing there about boost control (PWM) output on A11. Will the switch be low or high when grounded? Or can I just invert to change it to what I want?
1997 ITR
search "boost control parameters" in Help, Contents.
Butch
Post by Butch »
Thanks! I was using the contents to find it instead of search. Found it, explains everything.
1997 ITR
