Darton sleeves by ERL
Bore: 81.5mm (.020" over)
Stroke: 87.2mm
Displacement: 1819cc
Compression Ratio: Probably around 9.0:1, the compression test was 180psi across the board
Cams: GS-R cams
Cam phasing: set to +2 IN/+1 EX to help with the idle; no additional tuning beyond that. It idles at 270 to 280 mbar @ 1000rpm.
Stock P72 manifold (IAB mechanism not working), OBD-2 GS-R TB, unported head, Crower valvesprings & retainers, Wiseco pistons (-XX?cc), Eagle rods; shortblock assembled and race-prepped by Stewart Racing Engines.
Hondata S300 (duh)
GReddy Profec Spec B 2
PLX M-300 wideband
Motec 3bar MAP sensor
Injectors: PTE 1000cc/min (low-imp); Honda resistor box
Fuel Pressure: 52psi @ atmostpheric pressure
IAT's: 109 to 112 deg F (every pull)
ECT's: 192 to 193 deg F (every pull)
Ambient air temp: probably around 70 deg F
Parameters calibrated:
1.) Quick street tune on the LO cam (fuel mostly, minimal timing changes)
2.) Idle conditions and throttle closed, deceleration conditions - no dipping on throttle off
3.) WOT runs @ the following boost levels for LO and HI cams up to 7000rpm for the LO cam and 8500rpm for the HI cam.
11 to 12psi (by 5000rpm)
14 to 15psi
18 to 19 psi
20 to 22psi (by 5500rpm)
Tuned fuel mostly and a little bit of ignition timing
We also accidentally ran it with the butterflies closed for a couple of 11 to 12psi passes b/c the previous tuner didn't quite know what he was doing and clamped them shut....and he wonders why they couldn't make more than 265whp (after like 4+ hours doing WOT runs on the dyno and even after throwing 18psi of boost at it).
2.) VTEC crossover at 4200rpm. The turbo starts building boost at 3000rpm and has 4lb's at 4000rpm.
Results:
1.) 11 to 12psi = 265whp.....low-rpm runners only; = 325whp with the butterflies left open
2.) 13 to 14psi = 360whp
3.) 18 to 19psi = 256whp? I dunno b/c the Dynojet didn't plot the lines
4.) 22 to 24psi = 250whp? I dunno...the lines didn't plot, but it definitely ripped through 3rd gear the more SET BOOST and duty cycle we added.
5.) By the end of the night, we had done more than 40 dyno pulls over the course of 4 to 5 hours. About ten of them weren't full runs because we were either just ramping up steadily or only looking at certain RPM windows. She got to drive the car on the dyno after about 20 passes because it was quicker since I couldn't drive and tune.
6.) I know that we still need to go back and fine tune a good portion of the maps since I had to work off of someone else's map and we only got to touch a small portion of the maps. It'll be off to a Mustang Dyno or Dyno Dynamics dyno to finish up, and then back to the Dynojet again if we have the desire and care to spend the money to verify the big numbers.
7.) The turbo is pretty much almost maxed out, probably doing around 45 to 47lb/imin at 23psi and 8500rpm in the 60-some% efficiency island.
8.) I'll try to get the dyno files and post a few when I can. All I have are datalog screenshots and the calibration/datalog files. I'll also attach the calibration file I started working from along with the one following a idle and street tune that I did so that you can see the transition from start to finish.
One of the hi-boost passes @ 22 to 20psi. You can see how short the datalog is after it hits max boost, if it's any indication of how quickly it ripped through the last 3000rpm in 3rd gear.
The datalog reads 16 deg BTDC, but it's supposed to be between 15.5 deg and 13.5 deg according to the IGN HI basemap table.
