Wet Nitrous on s100
Posted: Wed Sep 27, 2006 10:05 am
I currently have an 89 civic with a b18a that has a wet nitrous system on it. The main thing I need from the system for the nitrous is to alter the timing when the nitrous is shot. I like the engine speed, throttle position, and mph features of the s100 but I do not need an increase in fuel from the vehicle fuel system as I have a separate fuel cell, fuel pump, solinoid, and regulatior.
I actually have a MSD ignition controler on it now that is able to retard the timing during the nitrous. I've been told by the tune shop that the MSD ignition controller will no longer be necessary with the s100 system.
What I am thinking is that I could hook both the nitrous and the fuel solinoid up to the s100 switch for the nitrous. I would have the fuel pump run on a separate switch that would remain on during a whole run. I am hoping that the s100 system will run on the same fuel map, or possibly just duplicate the standard map.
Will this work or is there something I'm missing...suggestions?
