hondata box LED HELP!!!!
i have the hondata s200 setup and when i turn the car on, the box doesnt blink and then stay on. it just comes on and stays on. i was reading the website and it said that the box should blink once and then remain constant. now when i start the car it will idle correctly, but as soon as you apply the throttle the car misfires and completely saturates the spark plugs. I have changed the base tune twice and still have the same problem. someone told me to check the distributor, but i was reading and noticed this thing with the led. if it isnt important to blink and then stay on then i know that it isnt the hondata that is messed up but i am beginning to question whether the box is malfunctioned or not. my friend bought a hondata stage 2 and his was a bad unit and had to be sent back. i bought mine from the same guy and am now wondering if mine is bad too. any help that you can give me is appreciated. I have a B20/Vtec with 440cc RC injectors, T3/T04e turbo, 3 bar map sensor, JG Edelbrock intake manifold, stock bottom end and stock fuel pump. If i have left out any info that you might seem pertinent please let me know. i would like to get this damn thing running right. Thanks again for your help.
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
QUICKSILVER RACING
- Contact:
You can't buy from me. I don't wanna F* up your engine. I only tune when I'm in front of the actual car.
Use ROMEDITOR3.
Create a new ROM.
Make appropriate selections and click the compensation part for the bigger injectors.
This map will still be off without the use of a wideband.
A customer I tuned earlier was running rich.
Use ROMEDITOR3.
Create a new ROM.
