How to Check ABS Codes w/S300
boost charger
Post by boost charger »
I tried jumping the service connector but that did nothing the abs light just stays solid.
Bore & Boost!!!!
"God created turbo lag to give v8's a chance" by TurboEK from SNI
http://www.cardomain.com/id/skrigz
The S300 has nothing to do with ABS codes.
boost charger
Spunkster wrote:The S300 has nothing to do with ABS codes.
so how do i check them?
Bore & Boost!!!!
NA2BOOST
Post by NA2BOOST »
Check abs codes by jumping the scs connector, the scs connector is also connected to the abs control unit. You CAN have a problem with a solid abs light with no codes stored.
check for
blown fuses
faulty abs control unit
open circiuts between abs control unit and under hood fuse panel
faulty altenator
open circiut from altenator to abs control unit
blown rear defroster/heater motor relay/ cooling fan motor relay fuse
I would higly suggest checking a Helms manual for the complete details on how to do this.
boost charger
Spunkster wrote:I would higly suggest checking a Helms manual for the complete details on how to do this.
wow thx
Bore & Boost!!!!
