IAB activation
Posted: Tue Sep 19, 2006 12:24 pm
by Shmaa
I have read that the IAB is controlled differently between OBD-I and OBD-II. One sinal is 12v while this other is ground.
So if I put an OBD-I P72 on an 00 GSR the activation will not work??
Now will inverting the IAB output correct this?
Posted: Tue Sep 19, 2006 12:35 pm
No. The ECU can either ground the output or provide 12V, but not do both. If the ECUs are different you need to rewire the IAB.
