Typical IAT JRSC??
SoOperGeeSeR
Typical IAT JRSC??
Post by SoOperGeeSeR »
According to my laptop... IAT reaches 230 cruising on the highway...after about 30 minutes... is this Normal?
This is not normal. Make sure your bypassvalve is functioning. IT should be closer to 120 or so cruising spiking to maybe 200 under hard boost runs then slowly cooling back down when cruising.
calvin
Post by calvin »
JRSC air temp is round 90 Degrees Celcuis if boost hard.
The air temp will be high if you removed/not used the jrsc supplied relay.
Zoomie
Post by Zoomie »
calvin wrote: The air temp will be high if you removed/not used the jrsc supplied relay.
The relay only works to fool the ecu into thinking the temp is lower (cold) than it actually is so that the ecu increases fuel delivery (rich mixture). It is a mechanical hack that should not be used with a programmable ecu.
The temp will actually be much higher than indicated when boosting with the relay. The relay gives a false reading...
calvin
Post by calvin »
IAT is very high due the JRSC. It gens alot of heat
picnic_george
Post by picnic_george »
Water/methanol..... Went from 230+ after 2 passes(on a 60* evening) and even higher if I'm hot lapping to a consistent 120-130* hot lapping on a 90* day.
SoOperGeeSeR
sorry guys... what is hot lapping? and your getting IAT at 230 and higher... i don't get it.... are other JRSC's running this hot? sorry i'm a noob..
Your bypass valve is not working correctly. It should only be about 120 at cruise. Contact Jackson Racing.
SoOperGeeSeR
how can i test to see if the bypass valve is working? when i pinch the hose shut...the little arm moves.. when i let go..it moves back... or is it more to it than that.... :shock:
There is a problem if you are getting intake temps that high while cruising. You will see temps as high as 200-220 under extended boost runs, but once you start cruising it will drop within a minite or 2 back to the 120-130 range.
I would suggest contacting Jacskon Racing for tech support.
