Disappointed with Full Throttle Shift Feature
RK
Post by RK »
For some reason...my rev limit is @ 7500rpm. If I touch the clutch, it'll drop down to 6000rpm as what the shift limit is set at. Speaking with others...it seems like a lot of people haven't had success.
I love the launch control feature. It helps a great deal...but what's the point when I'm limited at 7500rpm.
What gives? Anyone with success?
BTW, this is a Hondata Stage 3.
-Rod
QUICKSILVER RACING
Post by QUICKSILVER RACING »
What is youe Engine?
Safety before anything else. You can adjust it anyway. Read the manual. A cd comes with every new purchase. Maybe you bought it used?
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
RK
motor is..
Post by RK »
b18c1 p72 ecu
rev limit was set at 8300rpm. Worked fine before.
I just put in the clutch switch recently and is actin up.
-Rod
QUICKSILVER RACING
Then use the button switch to adjust the features of your Hondata.
Read the manual about it.
+639178954747
RK
Post by RK »
Yes I will try that tomorrow...but would the settings have changed?
94vtirozguy
Post by 94vtirozguy »
RK wrote:Yes I will try that tomorrow...but would the settings have changed?
Full throttle shift is working correctly. If you read the manual the dropping to 6k happens when your foot is resting still on the clutch (ie the button is depressed) and is a safety feature designed so the clutch will not burn out as quick and this is adjustable.
So my suggestion is you have setup the clutch switch incorrectly or after you change gears you are leaving your foot just enough on the clutch pedal to keep the button pressed causing you the revs to cut out at 6k (which is the default setting).
BplantCivic
clutch switch
Post by BplantCivic »
I remember a discussion a few years ago that a "whisker" switch was recommended over the pin switch that comes with the package. And mounting the whisker switch in an ideal location (at the pendulum of the clutch arm where the clutch engagement point is?). Maybe someone else that has done this can explain it in laymen's terms better than I... :mrgreen:
HONDA GHANDI
Post by HONDA GHANDI »
Ive been using NOS throttle switches for clutch activation. It is much easier to adjust your pedal "switch" point.
DaX
Post by DaX »
The throttle body mounted switch? Are you making a bracket and sticking it down by your feet? that seems like it would work better now that you mention it....
Please expand. :D
HONDA GHANDI
Yes the WOT switch for NX, NOS kits.
Pretty cheap and easier to use and adjust.
You can use the bracket that comes with it or fab one.
I mount it down on one of the clutch master studs and then bend the bracket as needed. I usually make it so the switch is activated at about half of the clutch pedal travel.
DaX
Post by DaX »
How does the switch not interfere with clutch pedal travel? Wouldn't it stop the pedal from traveling all the way down?
If you have a picture that would be helpful. :lol:
HONDA GHANDI
I have this setup on my racecar, Ill take a pic later today and post it up.
It will make sense when you see it.
