kmanager connection problems?
bimmafrik
Post by bimmafrik »
2004 Honda Civic Si (EP3)
K20a3 Ecu --> Kpro
-okay, when i purchased my ecu from a vendor they sent me the wrong the cd-rom (software), they sent me Smanager. So i never got a Kmanager cd-rom.
So i went ahead and used my friends laptop that already had Kmanager installed ( He has Kpro also)
-Now my friend is in school and there is now way i can get his laptop, so i decided to use my laptop and download the software off of Hondata.com.
-I downloaded the software, then when i hooked up the ecu to the laptop, the laptop had already found my ecu and i started downloading the USB drivers.
Then when it asked me to insert CD, i had no CD to insert... so it wouldnt download....
**so my question is...
-Do i have to have a Kmanager CD to allow to download the USB drivers to connect with ECU?
or is there another way around this to make it work?
Thanks guys in advance!
:D
Roy J.
You do not need the cd. Just point it to the directory where you intalled K-Manager.
If you go to Help, Contents, there are also detailed insturctions on how to do this.
bimmafrik
Post by bimmafrik »
Spunkster wrote:You do not need the cd. Just point it to the directory where you intalled K-Manager.
thanks, I will give it a try when I get home..
