Anyone successfully using 1600cc injectors?
sander
Post by sander »
We are in the process of changing from a competitors EMS to KPRO, wondering if anyone is using an injector this big?
Also, We ran out on the stock coils, We are using GM LS1 Coils, (they use the same square wave trigger signal as the stock coils) Has anyone used these with KPRO as well?
Thanks guys,
-sander.
learning.
qwk
Post by qwk »
I am running RC 1600CC injectors with a resistor box and havent ran into any problems
NauTech
Post by NauTech »
qwk
is your car idling okay ? at what rpm?
did you have to change the battery voltage compensation ? (injector lag/dead time) for it to idle correctly ? if you did what are your numbers
cause i have precision 1200 and i cant get it to idle great... even playing with dead times i cant get it right... so im in the process of changing to 1600 since ive read at multiple places that it is idling perfect but... at what rpm and did they have to change the dead times numbers... thats why i ask you
thanks
